That's crazy. If you can't find aftermarket, you can always weld in and blend extnesions into the existing stock fender.docwra wrote:and the rims Im considering are 48mm further out front and 56mm rear, is there any overfender or similar that would allow me to fit them??
those wheels you mentioned will not even come close to fitting, dont waste your time. I have seen a few crazy people with 19x10 -10 offset, but that about all you can go. 9.5inch +30mm offset will come close , if you dont plan on rolling you fenders. If you do roll your fenders, you can shoot for somewhere around 0mm offset on say a 9 inch rim but you may need some negative camber to keep from rubbing.docwra wrote:Ive got a 350Z that had an unfortunate incident with a hedge, ditch and roadsign recently
Due to this Ive ordered up a few new parts (Chargespeed kit for starters) but still need to get some new front fenders and possibly rear ones as well. I thought this would be a good opportunity to look into some insane wheel fitments with a view to buying fenders to match.
Ive found some Work Meisters but they are pretty wide with a 10.5 ET-9 front, 11.5 ET-22 rear. Now bearing in mind the fitment currently looks like this:
Ummm ......... thats 9J ET20 on the front and 10J ET15 on the rear with a standard arch in that pictureredsx13 wrote:9.5inch +30mm offset will come close , if you dont plan on rolling you fenders.
