Insane Engine Swap Help Needed
89 240 SOHC
Car: 1990 Micra S13....Micra with S13 Seats and other S13 accents to follow
I've got an old 265HP 4cyl race car engine I wanna dump into my 89 240SX Fast Back. The engine is from a 2.3L Mustang, .040 overbore, .500 shaved off head port and polish etc... I need some info on how to convert my car to run a cable clutch for this engine has anyone gone to a cable clutch before and if so how'd you do it? Also any comments are welcome
Ubernoober
It would be easier to go Hydralic. You would only have to bolt a bracket and cylinder onto the transmission and be done with it. I assume you are using the T5 that came with the 2.3L Ford.Look at the kits here. You don't need all these parts, but the bracket and slave can give you an idea of what you need. Heck, you could just buy this and delete the parts you don't need.http://www.jmcmotorsports.com/...lutch
89 240 SOHC
Thanks, Those kits look pricey but I might be able to make something work
