azboy »
https://forums.nicoclub.com/azboy-u7931.html
Thu Sep 22, 2005 8:21 am
most places will only sell you a short block. meaning no transmission, ecu, maf, harness, power transistor, turbo, IC, maybe even cylinder head, etc. if you don't already have a SR swap in your car, buying a blown SR to do a swap is the worse idea i've head in a long time.
but to answer the original question. not all compression and leak down gauges are equal. as long as the numbers are consistent throughout all 4 cylinders you should be good. hell, you can even talk them down a lower price due to the fact that those numbers are low.
