neverlift »
https://forums.nicoclub.com/neverlift-u39984.html
Sat Aug 23, 2008 1:52 pm
no no, I should edit that better, I was doing a burnout and my filter fell off(IDFK) and a 2 to 2.5 adapter band was sucked into the compressor, and was puked out.....
Well, I have driven it a short trip getting on it fairly hard, it seems fine, it spins free as before and just as smooth, the blade didnt come into contact with the housing, and shaft play is the same(pretty much none).I need to fix my wastegate block off to know for sure(only holds 5psi)...
So you think its out of ballance that bad? The same amount of weight is on the shaft.
also where to get a new wheel? and how to know what wheel? I know those are newb Q's but I just dont know
