innovate LC-1 wideband o2 sensor....
LOVERboy
Car: 1997 240sx se KAT
can i use the yellow or brown wire to connect to the stock o2 sensor wire?
"6. Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2) can be connectedto the analog inputs of other devices such as data loggers, ECUs, or gauges. If either one orboth of these wires are not being used isolate and tape the wire(s) out of the way. The defaultanalog outputs are as follows: Analog output one is 1.1V = 14 AFR and .1V = 15 AFR. This isa simulated narrowband signal. Analog output two is setup as 0V = 7.35 AFR and 5V = 22.39AFR." - innovate motorsport LC-1 manual
nissanman04
Car: '90 240SX, '95 Subaru Legacy
Use the yellow wire to simulate the stock o2 sensor. The brown one is to be used for your wideband gauge.
LOVERboy
okay. Thx you!!!
