I didn't realize a driver could have such an impact on the camber. Very good interesting info.Q45tech wrote:Within wide oem specs is the problem! Perfection requires setting and maintaining at the exact midpoint of specs as you drive.
Most [95%] of tires are designed to tolerate a negative 0.5 degrees of camber....................-1.0 deg is significant and both sides should be matched within 0.25 degrees [closer is better]
A drivers weight in the seat will change the left front camber up to 0.4 degrees depending on driver weight.
I thought the wheels on the G coupe were not rotatable. Yet another reduction in tire life. Do I have this wrong? Are you talking about left to right rotation? I thought you could not do this on radials. Please explain.lawson3 wrote:G35s have no camber adjustments for front camber from the factory you will need to install camber plates(or some sort of aftermarket kit) on the front to ease the negative camber,this is common on more cars than just infinitis these days.On my sedan its not that bad ,I keep my tires rotated often to help inner edge wear.I hear its worse on the coupes though.Being a honda tech this is also common on the S2000 and other hondas,pretty much the price you pay for a high performance car.
The feathering is a common problem with all Coupes on front tires. There is no getting away from it other than installing an expensive camber kit. Your second option is to slow the feathering down to get the most miles out of your car. This can be done by setting the toe to the max within the allowable specs. For instance, if the specs for the front tire toe is 0.00 to 0.08 it would be adviseable to get as close to 0.08 on both tires as possible. This will slow down the scrubing of the inside of the tires. In addition, in response to your previous question with regards to rotation. You can rotate your front tires from side to side. You have two options. If your tires are non directionial, you can just move each tire to the opposite side of the car. However, if it is a directional tire, you need to dismount each tire, flip the tire around on the rim, remount the tire, and then place it on the opposite side of the car with a rebalance. Sounds like a pain? Welcome to the club! The Coupe eats tires. However if you do the above, you can get some extra miles out of your front tires. The rear tires are another issue. If you have the stock factory rims, these tires have a tendency to wear prematurely in the middle treads. The only possible solution for this is to get aftermarket rims with wider rims to accomodate the spread of the tire footprint. I have 20,000 miles on my 04 Coupe and I'm on my 4th set of tires due these issues. I'm have been close to throwing in the towel. The noise alone from the front feathering can make you go mad!!!!!! The car is still a good value, and all cars have their issues. It's all a matter of biting the bullet.Mr spock wrote:
The Sedan does not have the same aggessive front end set up that the Coupe has. Although the sedan does not have camber settings either, it does not manifest the inside front wear that the coupe does. My girlfriend has a 06 G35 Sedan and the ride is quiet as a churchmouse. Not a sound to mention from the tires. After 11,000 miles there is no inner feathering to talk about. Besides, the sedan of course has the luxury of rotation. The coupe sits lower and for whatever reason, road noise is more prevalent. When it rains, you can hear the water crashing against the inner fender protectors. If tires and road noise is an issue, definitely consider the sedan over the coupe.Mr spock wrote:Thanks for that explanation Bocatrip. I was not expecting such severe tire wear! And I'm very sensitive to tire and road noise.
Why is the coupe worse than the sedan?
