inline check valve after brake booster. do i need it?
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
ive never run it. is it needed? if so where do i get 1?
thanks
float_6969
Yes you need it. You'll have to get it from Nissan, or the junkyard.
splintercell
what is its purpose? junkyards around here suck and dont carry nissans.
ragenasian
Car: AE86 w/CA18DET
Nissan charged me 50 bucks for the one for my truck. These things are usually like 12 bucks. Stupid dealer parts.
You got some mail by the way splint
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Ok, the booster works on vaccuum. On a turbo car, when you are on boost, there is the opposite of vaccuum. If your throttle gets stuck on, your brakes would work worse than having no booster at all.
Also it stops the diaphram from rupturing on 30 pound boost.
Generally it wouldn't rupture from the boost, as we know 25psi of vaccuum is what it expects normally. It also stops oil from the turbo going into the booster, which will rot the diaphram. A hole in the booster diaphram will be a vaccuum leak, which is bad for MAFM equipped cars trying to idle.
Yeah go to the wreckers, find the newest looking one off any car that has the same diameter vaccuum hoses. It's not rocket science.
splintercell
dattodude wrote:.
ok, thanks for the smart *** comment. like i stated above the junkyards around here cater to rednecks. THERE ARE NO NISSANS TO GO PULL PARTS OFF. im sure nissans are a dime a dozen your way. im not so fortunate. ill just go to nissan and see if i can get one. w/e
lostmenoggin
Car: 1989 Nissan 240sx ca18det swapped
Calm down mang. He meant you can use one off of any car that has the same diameter hose. Chevy, Ford, Dodge, whatever. They all do the same thing.
splintercell
i did some research and got the nissan part #. this fits many different model nissans. im going to order a new one to be safe.
N4030-233546
float_6969
I don't think he was intending to be condescending. It's simply a check valve and serves the functions stated above. You can go down to your redneck junkyard and get one from any car there. AFAIK, all cars have them.
RS12Turbo
Hmmm, interesting. Where is this check valve located......on the big vac hose that goes from the booster to the back of the intake plenum? As far as I know, my S12 doesn't have one......and I didn't even mess with the s12 brake booster vac line when I did my swap...other than putting it on the nipple on the back of the ca-det mani.
splintercell
i ordered one from nissan today for 30.00.
"its not rocket science" is trying to make me look like an idiot in my book. oh well. i was just asking a simple question.
biosehnsucht
RS12Turbo wrote:Hmmm, interesting. Where is this check valve located......on the big vac hose that goes from the booster to the back of the intake plenum? As far as I know, my S12 doesn't have one......and I didn't even mess with the s12 brake booster vac line when I did my swap...other than putting it on the nipple on the back of the ca-det mani.
It sits between teh two halves of the brake booster hose. You'd easily mistake it for a coupler, if you didn't know what it was.
RS12Turbo
So what exactly is it's purpose?
dattodude
You should have been able to get one for free from any make/model at the wrecking yard. At $30..at least you know it will fit.
Lighten up man. Sorry if you got offended.
But like the followup posts said, anything from any car will work. You just gotta get the pipe diameters correct. Anything Nissan should have been fine.
splintercell
dattodude wrote:You should have been able to get one for free from any make/model at the wrecking yard. At $30..at least you know it will fit.
n/p man, sorry. been under some stress lately. thanks for the help though. yeah, at least i will know this one works from nissan. other websites were the same price by the time you added shipping.
