Injen Heat shield?
All things Altima Coupe.
D-Roll
Car: 08 Nissan 350Z Touring Coupe
So those who have the Injen intake w/the heat shield...do u think it is worth it? Or just for looks? Thanks
Mr. Music
Car: 2008 Altima Coupe 2.5S CVT w/ Convenience Package
In the family: '02 S15 Spec R, '09 Rogue
It does protect it from the heat, but the filter is so far a way from the engine that it doesn't really matter much, I guess. Considering that the Fujita and Stillen intakes don't have a heat shield, I'd say its mostly for looks.
D-Roll
Mr. Music wrote:It does protect it from the heat, but the filter is so far a way from the engine that it doesn't really matter much, I guess. Considering that the Fujita and Stillen intakes don't have a heat shield, I'd say its mostly for looks.
yeah I agree. I left me stock ram air part on so air still gets to the intake from the outside.
Mr. Music
I took that off... cleans up the engine bay a lot.
cuzzbubba420
Car: 08 Altima 2.5 S w/ CVT
It wouldn't make much difference IMHO
D-Roll
Mr. Music wrote:I took that off... cleans up the engine bay a lot.
I agree, it does clean it up a bit
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
i'm thinking it might help keep one side of the filter cleaner longer then I rotate it around once a while
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
the heat shield doesn't really do much
D-Roll
adidas2go wrote:the heat shield doesn't really do much
Thanks for the info bro. Did you remove the stock ram air vent as well?
adidas2go
I left the one that is connected to the bumper, no reason to take it off, unless your going for pure aesthetics. Otherwise, all its doing is letting colder air into the engine, good things
D-Roll
adidas2go wrote:I left the one that is connected to the bumper, no reason to take it off, unless your going for pure aesthetics. Otherwise, all its doing is letting colder air into the engine, good things
My thoughts exactly
Absolute Zero
Car: '08 Nissan Altima Coupe
I took mine off and promptly put it back on, It doesn't look very clean under there without something to cover it up, and like these guys are saying, I think it does add a little more fresh air into the engine bay.
Mr. Music
With or without the "stock ram air vent", the air is still getting into the engine bay, but it just isn't being pointed toward the filter. If you go pop it off, you'll see its inlet (at least I can on my 2.5). For you 3.5ers, its not as big as on the 2.5. so it isn't as ugly.
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
i took mine off shortly after installing the injen. i think it looks better and it wasn't directed right at the filter so that was my reason for removing it and it was just flopping around in there.
DEVND32
Car: ALTIMA COUPE
i have a injen intake, but is everyones intake really loud?
