injectors wont fire after fixing leaky o ring????
lorenzoke45
Car: 1990 nissan 240sx
redtop sr
enthalpy tuned ecu
z32 maf
gt3071r
740cc injectors
two days ago i was doing a good second gear pull and the car lost all power. couldnt get it to start and it was late so i had a buddy tow me home.
when i went to start a diagnosis the next day i noticed that my #3 injector was leaking like an open faucet from the top of the rail. pulled it out, replaced the chewed up o ring that was on it fixing the leak and what i thought was the problem but the car still refused to start. pulled the rail today and found out that now none of my injectors will fire.
did a good amount of searching and couldn't find a similar situation (aside from those that had just done the swap and had their fuel lines backwards)
can a leaking injector cause damage to the electrical system somehow?
hoping im not looking at fried ecu.
have spark, good fuel pressure, compression, no ecu codes.
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I would first check the voltage to the injector connectors. Then check the resistance between each injector's pins to see if they are all close to each other.
