Injectors to work?
95hondakillr
Car: 240s
O.K. guys this is going to sound retarded but what do I need to do to covert to my top feed injectors besides using the top feed rail. I know I dont use the side feed rail to mount them so do i get o rings big enough to fit the injectors directly into my manifold? I know this is 101 but I was talking to someone about this today and they just totally confused the hell out me and i want to be sure i do this right. Thanks.:oface
andrave
Car: 1989 Nissan 240SX Coupe
you will need brackets that mount the rail, most of the custom ones have those on them already. you will need a fuel pressure regulator. and your injectors probably have all the seals on them you'll need. If not get new ones.
erich
You will also need to put new plugs on the wiring harness for the injectors.
andrave
oh yeah.or depend on the design you might be able to cut yours to fit.and that reminds me, if they are low impedance you need some resistors.
95hondakillr
Car: 240s
How do you get your new injectors to fit right into the intake mani without leaking? BTW thanks for the above replies:)
