injectors to run?
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
im going to pick and pull tomorrow and im gonna try to get some injectors for my ka24e to put in when i turbo it.
my question is what injectors should i get that will fit in?
my plans are to only run around 8 or 9 lbs of boost so what car could i get some injectors from??
480sx
Car: 1996 Pearl White 240sx
Third post from the top, the one thats ironicaly named READ THIS FIRST, is the one you want to.. Ermm im not sure.
zerothread/99647
More specificaly, to your exact question of what injectors fit the Ka's rail, read this --->zerothread?id=109492
But to actualy answer your question myself, i would say you could get away with the SR 370cc injectors if you are running a t2 sized turbo. It kinda depends on your turbo.. You also have to have somthing to control the upgraded injectors. Read everything in that post then if you still have questions ask us.
Craving4Boost
Car: 91 240sx fastback
370cc's from a SR would be good for his amount of boost but keep in mind he is running a SOHC motor which is topfeed and not sidefeed.
driftmyke - look at the sticky that 480sx linked you and choose for yourself whatever "pick and pull" has conveniently. But do remember that you will most likley need a resistor pack. Grab one from a DSM
ripperstatus
Car: 1990 240sx
ok cool, so i guess im looking for a na elcispe. also what is a resistor pack and why would i need it. sorry for stupid questions
