That is a picture of my engine. they don't need to fit the stock rail, as they are mounted on the intake manifold. so what year gtr had these top-feed injectors? 440cc? my plans are for 555cc mains and these as secondary. that should be enough fuel for some big boost! btw, this motor came like this with the eight injectors. also a k3t turbo kit, and a metal headgasket. got it from yury and jeff! as soon as i get my flywheel turned, i can put my clutch on it and put in the shell! woohoo!shaunthemadscientist wrote:same injector for both 440 or 444cc, I forget the exact flow but as i said it won't work with a stock SR fuel rail.
