andrave »
https://forums.nicoclub.com/andrave-u6358.html
Thu Jan 22, 2004 7:16 pm
OK, first off, what is more expensive for you and I isn't always more expensive for companies like nissan... first consider that most of the side feeds are made in japan, so they are cheaper in japan. Then consider that nissan doubled up on its injectors sizes (ie, the 370's fit vg30dett, sr20det, etc) so they were buying them in orders of hundreds of thousands per.Anyway, having said that, supposed side feeds allow you to run a higher duty cycle per injector size... I also read someone say that the fuel flows around them as a coolant of sorts, keeping them cooler and therefore increasing their duty cycle. Also I've read that high impedance injectors are "easier" to control somehow than top feeds, especially at high duty cycles.Anyway, I can't answer that question definitively, and I doubt anyone but the engineers that worked on that engine could either. It is true that sidefeeds are more prone to leaking than top feeds, too...ultimately its a decision of economics. You gotta buy/make/ghetto up a fuel rail for top feeds, but they are usually substantially cheaper than side feeds...
