thanks alot finally a positive response..OutToWinPAHC wrote:Under the technical section we have a Ka-T section. Some good info in there, as and its traveled by the techies often. Check out there and see what others are using. I know budget KA-T builds use te SR20 injectors a lot.
where are the classifieds at?OutToWinPAHC wrote:Under the technical section we have a Ka-T section. Some good info in there, as and its traveled by the techies often. Check out there and see what others are using. I know budget KA-T builds use the SR20 injectors a lot.
