vocationalzero »
https://forums.nicoclub.com/vocationalzero-u87315.html
Sun Mar 22, 2009 10:56 am
Unplug the cam angle sensor, pull out the cam angle sensor, plug back in, set car to ON position, turn gear by hand and listen to the injectors and see if you hear a clicking sound. It sounds like a solenoid click. The CAS controls the pulse signal for the injectors. If you don't know what a solenoid click sounds like, do a quick hard wire test to one of the injectors to give you an idea of what it sounds like. But I bet 95% this will fix your problem.
