donkizle wrote:first question is how huch boost can i run on the stock bottom end?! SAFELY!
Question about your question. What turbo are you running? Different turbo's have different efficiencies.
donkizle wrote: second, at that amount of boost what size fuel injectors do i need.
Again depends on what turbo you have.
donkizle wrote: and third what is the best , but still cost effictive , engine management system?
Depends on the turbo and your power goals.
donkizle wrote:also what size fuel pump do i need?
Depends on power goals. At Minimum 255lph.
Edit:
srdub-t wrote:it depends what size turbo your running and for engine managment i like enthalpy. For injectors search the forum and youll find good info.
Doh. Beat me to it.
