injectors
spyin.inu
Car: 89' 240sx hatch, 90' 240sx hatch & 96' 240sx SE
it seems my 1ts and 3rd injectors are screwed
i put $30 of 93 gas in my 90' 240(KA24E), and it put me in between 3/4 and fulli reset my mile dial thingy to 000.0 then i notice im losing gas, i have done about 66 miles since then and im not speeding
last night i saw i had something under my fuel rail/injectors so since i didn't have good light, i waited till morning to do it
i have about a hair under half a tank....so i checked my injector area with the good lighting and saw i had gas some gas under the injectors
so i cleaned it and then went to work hoping it wasn't anything bad, just something i haven't seen before
so i got to work and saw it was there again, so i got a paper towel and got it up and it smelled of gas
would this be my injectors? i haven't been doing in harsh driving or anything
like a friend told me not to go over 3rd gear, since i don't need the engine heating up too much
this is my only ride, so i still need to drive it
some one please help me
frobro85
Car: 1991 240sx coupe
From the discription it sounds like leaky injectors and the o-rings are now done, it happends. It might also be leaking from the rail. As far as not upshifting just keep the rpms low and you will be fine if you are that worried.
S13FX
Car: '69 l20b Dimeski :)
Go to Autozone and get your set 4 sets of injector repair kits. They come come in boxes. Each box has all the rubber rings you need to replace on one injector.
It's also a very straight forward and easy fix on the KAE since its a top fed rail. Just make sure when you unplug the fuel lines which you shouldn't have to if you unpressurized the fuel system.
But just in case you do make sure you put them on the correct way.
spyin.inu
well its basically fixed nowwe put 3 different o-rings in itthen we settled on some a\c o-rings and they work
i need to get some fat rings since the injectors i have are small at the top compared to the fuel rail hole
so we're currently using 2 o-rings per injector until i find the fatties
DALAZ_68
Car: 90' 240sx CA18det
spyin.inu wrote:well its basically fixed nowwe put 3 different o-rings in itthen we settled on some a\c o-rings and they work
i used A/C rings too lol
spyin.inu
lolmine are a bright greenwe dropped affew in the grass and lost them -_-
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
spyin.inu wrote:fatties
HAHAHA you said "fatties".
xs04298
Car: 1989 240SX Hatch/1991 240sx SE hatch
I wish mine would solve this easily, im now no injector set #4 and o ring set #8 and fuel rail #2 and sob still leaks lol
16mpg for 3 years is sad, but the fact it hasn't caught on fire (yet *knock on wood*) sure is impressive...if only the scca would let it pass tech
Fla240sx
atleast I'm not the only one with leaking gas all over the place
I feel better now lol
xs04298
I can't decide if its something wrong with the fuel rail that it loses its grasp on the o rings over time (expands, scratches ect) or the injectors just dont sit right after they've expanded over the years or what, but something is messed up with it. Could even be the fuel rail/manifold are warping over time.
Ive never found an (afordable) replacement fuel rail though, and im not sure how to go about finding an oversized o ring
DALAZ_68
spyin.inu wrote:lolmine are a bright greenwe dropped affew in the grass and lost them -_-
LOL SAME HERE
xs04298
so clearly i have to find some of these bright green o rings! lol
irichjohn
Car: 1991 nissan 240sx
hey man do u have obd1?
irichjohn
hey man how do u take out the fuel injector coz its really hard.
4cefed
Car: 92 240SX Coupe
03 SRT-4
Various Dodge POSs
I hope when you guys are replacing O rings that you a lubricating them with some kind of oil or vasaline. Besides avaiding tears and scratches in the o rings, it might actually keep the o rings pliable over time a more resistant to drying out.
