S13Ka24e »
https://forums.nicoclub.com/s13ka24e-u2588.html
Sun Jul 06, 2003 11:26 am
The ca18det with fit, but the are incorrect impedance. The SOHC ka24e use high-impedance, were the ca18det are low-impedance. RC's injcectors, or you could use 36/lbs injectors from bosch or the like they will fit and are close to 370cc.
Edit: The biggest injector that you can run with the stock ecu are 310cc and they will run just barely rich. To run 370cc you need either a piggy back fuel control (S-AFC or the like) or you need a hacked MAF.
