mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Thu Aug 30, 2007 6:25 am
It's probably one of these three things: you have bad wiring, or burnt out injector drivers on the ECU, or those injectors are clogged/toast.
Try checking the continuity on each injector wire, from the injector connector plug all the way back to the ECU harness connector. I think you'll find a short or bad connectors somewhere... If you find that all six wires check out good, then pull the rail off and swap injectors #1 and #2 to see if the problem follows the injector, or stays on the cylinder... That will tell you if it's bad injectors or bad ECU.
