Injectors
89'ClubK's
Car: 89' Nissan 240SX
Will the factory injector harness work with 450cc injectors from a DSM, or do I need the DSM wire harness? thanks!
c-rad
Car: 1991 Nissan 240SX w/CA18DET
89’ClubK’s wrote:Will the factory injector harness work with 450cc injectors from a DSM, or do I need the DSM wire harness? thanks!
I'm using DSM injectors...the connectors are the same. Although I did have to machine my fuel rail to fit the injectors. The ports are just a hair too small for the DSM injectors.
mbmbmb23
Factory harness clips on, you'll need CA18DE/T injector O rings though.
89'ClubK's
Thats what I thought. Just wanted to make sure before I take off the upper half of my intake, and take the chance of being stranded. Thanks!
c-rad
I used the CA o-rings... I still needed to bore out the ports a little on the rail.
89'ClubK's
Thanks!
