Injectors swap, who knows about this?
EJ22t
Car: 95 s14 R33/conversion 98 2.4rs-t hybrid
I have heard the subaru and nissan injectors can interchange I want to know what it would take to make side feed injectors swap out?Im sure the plugs are different is there a place you can get adapters for that?
EJ22t
are the sr20det injectors peak & hold or saturated?
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Yeah, any side feed subi injector should fit the Nissan fuel rail, don't know where to get the connectors though (other than a donor car).
Most of Nissan's injectors are Saturated (high impedance), the only ones that are P&H (low impedance) are CA18DE/T (some?) and GTi-R SR20DET (both of which happen to be top feed injectors).
EJ22t
ok this paints a lot more clearer picture for me thank you, but do you know if there is a need for resistors even though they are both high impedance?
Seishuku
Nope, as long as they're higher than 10 ohm, it shouldn't need a resistor.
EJ22t
now the only question is how can I temporarily hook them up to see if they're going to work
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
Connect them to a power source and listen for them to click
