Injectors sohc to dohc??
Sxse240
Car: cars, computers, moneys, significant others, sometimes the stickey green.
So i just got a fuel rail from a 91 240sx to put on my 90, well i can see the fuel rail doesnt fit..but all i need is the injectors so please tell me if the injectors fit..and noone has to ***** at me about searching i have other questions. If they do fit how in gods name do you get them outta the rail, and 2 how the hell do you get the electric clips off the injectors from the sohc?! any input would be great thanks.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
The SOHC and DOHC injectors are different and incompatible. They should, however, pull straight out of the bottom, as they are sandwiched between the fuel rail and the intake manifold. And to remove the injector harness off of the SOHC, you must first pull the tiny metal wire retainer, then you can pull the harness off of the injector.
Sxse240
You absolutley positive that they are different. ..because @#%$
Toahk
Car: 97 ....
Yes SOHC are top feed and DOHC ones are bottom feed I believe.
bj180sx
Car: cars
different pulse too.
trpower7
That won't work at all. A simple visual inspection would PLAINLY denote this.
