i was installing my fuel rail on to my new godspeed manifold, i looked inside the manifold and the injectors were cramped up against the side of the manifold. i didnt know if this was a big issue, or no issue at all. i didnt think it would affect the spray pattern but when i asked around i was told it would affect the spray pattern, and it could cause the cylinders to run lean, and if too bad, it could eventually do harm to the engine. (i was warned about knock off s*** but didnt listen
after talking to someone else, i was told don't worry about, it will not effect anything. so which is it? heres the pics
heres how they sit in the polished manifold
heres how they sit in the cast manifold
where can i get these plasic bushings that sit between the fuel rail and manifold? one cracked on me
