chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Sat Mar 04, 2006 9:27 pm
dont put the injectors in by tightening the caps, this almost always results in ripped o rings. do it like this -
put the o rings on the injectorsput a little bit of vasolene on the edges of the o ringssupport the fuel rail with some wood blocks so you can push down on the injectors without the rail moving aroundpush the injectors straight down into the fuel rail, you can spin them if you need tothey will pop in, and sit flush with the rail surface, maybe slightly sunken inif the injectors are sticking out of the fuel rail more than about 1mm, you need to keep pushing. you will feel it pop into place.when you screw the caps back on, they should be completly flush with the fuel rail, if there is a gap between the cap and the rail, then the injector isnt all the way in.
