duffman1278 wrote:tru tru, just switch them around and see what happens on the injectors
....and if they are good, I would be doing the compression test for sure.
My car idled fine, sounded good, and drove just fine (like 35 miles) on an engine that had melted the side of a piston off. Obviously down on power, but idling it was good. I changed sparkplugs, swapped packs, and swapped injectors all on the side of the road....when I got home I everything off of it, took th emotor mount, and found my issue.....
