ALot of times it just reverts back to a bad wiring job and there's no sticky to prevent that. There's just waaaaaaaayy too much information on this forum that people don't take the time to review. I sit back and watch members crash and burn because most know everything else but how to wire-up a CA18DET install. But in your case, if your are sure you've done everything correctly, start looking at another ecu. Those get damage or already damaged before you take ownership, so it's hard to blame anyone but the bad ecu itself.rovert wrote:As far as the injectors not getting fuel through them...
JOIN THE CLUB!!!!!!!!!!! Somebody needs to sticky the remidy, You wont believe how many people on here, and other forums, have this same problem. I have spark, fuel, dropping resistor, timing but no damn fuel is getting into the cylinders!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
True that.boost_boy wrote:ALot of times it just reverts back to a bad wiring job and there's no sticky to prevent that. There's just waaaaaaaayy too much information on this forum that people don't take the time to review. I sit back and watch members crash and burn because most know everything else but how to wire-up a CA18DET install. But in your case, if your are sure you've done everything correctly, start looking at another ecu. Those get damage or already damaged before you take ownership, so it's hard to blame anyone but the bad ecu itself.
Dee
They put the CA in p/up truck.float_6969 wrote:Wait, is this a FWD, car?
