fanmanflex »
https://forums.nicoclub.com/fanmanflex-u48579.html
Sat Oct 03, 2009 9:57 am
Need help diagnosing injector problem. Had this prob last winter on my dohc so the car sat for a while. Fuel pump is working and getting fuel to the rail but the injectors aren't opening. took out the rail with everything hooked up, fuel is going into feed and out return but when i crank it the injectors are not spraying.
Recently rebuilt the motor to stock over the summer and obviously still having the issue.
Tried all the grounds made sure they're hooked up well, and they're getting the constant 12v just ground is not switching. Thinking it could be maybe the fpr open to much and not letting injectors open? or crank/cam angle sensor? idk.
Can i check the sensor with a multimeter anyone know. any help would be great.
Modified by fanmanflex at 7:07 PM 10/3/2009
