b16acrx1988 wrote:alright everything is getting power except for the injectors have gone through everything i know of and checked to see why. Have gotten an ohm meter and checked the injector plug and it isnt getting any reading at all from the plug at any time, i cant figure this out it is getting spark just changed the coil packs will start with starting fluid, but no fuel on top of cylinders, fuel pump is pumping like hell, just no injectors
Usually, if you don't have a injector resistor, your injectors won't get any power. If you have an injector resistorm you screwed-up the wiring job or your ecu is done.
Dee
