boost_boy wrote:
Is your injector resistor hooked-up?
Are all wires from your engine harness grounded?
Do the terminals at your injector plugs show voltage?
Are your fuel lines hooked-up correctly?
Answer these questions and I'll do my best to help you with your dilemma.
Dee
Where do i find the injector resistor? I see in the FSM a dropping resistor, but either my harness didnt come with one, or i am completely overlooking it.
Yes, all wires from the engine harness are grounded, per Heavythrottle.coms SR wiring instructions.
No, the terminals at the plugs show no voltage at all, nor do they trigger my test light, either cranking or otherwise.
Yes, fuel line comes into fuel filter, through fuel pressure gauge sending unit, to rail, out rail, through pressure regulator, to return line. And if i leave the key on long enough with the pump running, some fuel seems to leak past the injectors and it 'almost' catches for a second. But after that it continues to crank and not start. Ive even cranked it without the #1 plug in and got no fuel in the cylinder. So the injectors are definately not firing.
I even recently purchased another ignitor (before i learned how to test my other). Its definately not spark related. I picked up a voltage meter today too, and that shows me im still getting nothing at the injector plugs, nor from the ECU pins that fire the injectors. So somewhere, something isnt telling the ECU to fire the injectors. But the coil packs are firing just fine (shocked the living crap out of me testing it while my friend was cranking it).
Timing has to be dead on too, at least cam to crank timing. Ive moved the CAS forward and back between cranks and nothing changes.
I do have Venom 550cc injectors installed, and currently have the stock EPROM installed, but regardless, im still not getting signal at the injector plugs. And yes, ive socketed the ECU already and have written a tune for the 550cc's, im just using the stock EPROM to elimanate my tune as a reason for the no start.
Thanks for reading this and all the help so far, Dee. I love this motor and know its going to be a badass. Its just right now i feel like im banging my head against a wall.
Jason
