theramz »
https://forums.nicoclub.com/theramz-u175698.html
Mon Feb 11, 2013 10:18 am
I just got a new oem knock sensor for $15 shipped off of ebay. You can buy them all day long for $39 shipped. Nissan used the same # on most of the cars. Gasket sets are available from partsgeek.com. All the hoses are vacuum so it's easy to match them up if they are leaking otherwise don't take the manifold off, it's a b**** to do. Check the relay for the wipers and the fuses before you take the car apart. Gas line is easy except for the one going to the fuel rails at the rear. Coil packs seldom go bad, check your plugs first. Since the "92 doesn't have a diagnostic plug I bet the chumps that told you all that crap don't no any more than you do about it. I got a factory repair manual on cd from ebay and it shows everything on the car. The hard copy is 1300 pages.
