Injectors(GTR,GTI-R)
sr20detconv
Car: 1989 silvia k's
My question is ,are the gtr and gti-r injectors bolt-on to my stock fuel rail and stock connectors?I think both are 444cc but are they the same?So do I need some other modification concerning those injectors(resistors,etc).And how much are they worth?
Bwana
Car: Denali
They will fit you fuel rail and connectors perfectly. The CA harness already uses low ohm injectors, so no need to change anything there. You will need a new tune to your ECU or a piggyback or something to properly control the larger injectors. They should run something like $1-200 for a used set...
sr20detconv
No need for more info.Thanx alot
nismoplsr
What are you putting these injectors on? A CA or a SR?
I think the GTiR injectors are side feed, while CA are top feed. So they wont fit at all if i am correct about the GTiR being sidefeed.
Sil40sK
Car: '93 Nissan 240SX
'88 Porsche 911
'02 Ford Focus SVT
Nope GTiR injectors are top feed just like CA injectors. They're 440cc. Skyline's are top feed and 444cc. Both low impedence.
sr20detconv
For what HP are they good for?
Sil40sK
'88 Porsche 911
'02 Ford Focus SVT
From what I know, they're good to a little over 300whp, depending on tuning, turbo, etc.
themadscientist
Sil40sK wrote:Nope GTiR injectors are top feed just like CA injectors. They're 440cc. Skyline's are top feed and 444cc. Both low impedence.
Nope, same injector, 444cc
