Injectors for a t3-t4 turbo kit on a 95 s14?
fuzzy240sx
Car: 1995 Nissan 240sx
Do I need to get bigger injectors for 15 pounds of boost on a t3-t4 turbo kit for a 95 s14? It's a kad14. Thanks.
StryfeS13
Car: 1993 Nissan 240SX
Oh, wow. Bro, you need to do some research before you blow up your motor. I'll answer your questions though.
There is no such thing as a "kad14." It's a KA24DE.
And yes, you absolutely need larger injectors for a t3/t4 on 15 pounds of boost. You also need a fuel pump, a MAF, and a tune.
What does your setup look like?
Should be along the lines of:
Turbo
Manifold
Downpipe
Hotpipe/Coldpipe
Intercooler
Z32 MAF or other
550CC injectors or more
Boost Gauge
Wideband (YOU NEED THIS)
Tune
Walbro 255lph fuel pump
ETC.
It's also extremely smart to do a tune up before you boost it, and fix any and all leaks, or issues that you may have, because when you boost it, they're gonna get 10X worse.
