Although I have not bolted the ecu in I have a ground wire connected to the ECU itself and to the motor which is properly grounded. When I take the ground from the AAC valve the injectors fire properly. When the AAC valve is plugged in the injectors only pulse randomly and each time they pulse the AAC valve "clicks"?.240z4u wrote:The ECU grounds the injectors in order for them to fire FYI.
