I don't think a rehab at Deatchwerks will help unless they are ohming in the 12-13 range (cold). Any higher and the ohms will soon be on their way up and out. I've replaced 4 injectors on my Q and all have followed the same pattern.ScottJackson wrote:....it seems those cheap $60 remanned injectors that are ohm tested would be a good option since they should be decently well sealed up from the elements when rehabbed. Thoughts?
Since the resistance is higher than it should be, it would appear that the corrosion is in series with the original circuit path. (Only excessively low resistance would indicate a parallel corrosion path). So, removing existing corrosion wouldn't do anything to reduce the resistance...by itself, anyway.Q45tech wrote:I wounder if you could cycle [no more than 50% on off on] voltage to the coil and melt corrosion
Like D said when storing a vehicle for long periods of time always drain the tank and make sure your car has fresh coolant. Coolant can be very damaging to your vehicle if it's old especially during storage. With our G50 injector issues we have to also drain fuel rail. If U can afford a climate control storage it helps with brake system, belts, and tire aging.greenwar wrote:Wowie this is scary. I am putting my cars into storage. What should I put in the gas to prevent my injectors from failing.. Fuel Stabilizer?
Pete have you ever seen the inside of your gas tank. It varies from Q to Q depending on up keep. BG44K is very good every other oil change and fuel filter at factory recommended intervals are good enough when using BG44K. I have seen the inside of quite a few tanks and some are crystal clear and others have trash in the bottom.Peterofdevon wrote:What then (regarding the dangers of potential ethenal issues/injector age/vehicle age should we do to prolong injector life?
What's the best fuel addititve? How often should we use it?
Should we increase fule filter replace intervals?
Peter
