Injectors by yrs.
QDog26
Car: 1992 Pearl White Q45
Can anyone tell me the difference between injectors for the 1991Q and the 1992Q? I was told that injectors from the 1991Q won't fit the 1992Q, is this accurate?
goody90q45
Car: 1992 Infiniti Q45 (sold)
90-93 are the same and interchangeable, 94-96 are the same and interchangeable, but you can't use a 90-93 in a 94-96 and vice versa.
There's debate about whether you should match the dot color but the consensus is it's only a spray pattern and makes no difference what color dot is used. Once the outside of the FI is cleaned with about any cleaner the dot is gone and the you treat them all the same anyways.
QDog26
Thank you. That was very helpful.
