compression »
https://forums.nicoclub.com/compression-u9345.html
Thu Jan 24, 2008 10:17 am
You dont need bigger injectors unless your stock injectors are not able to flow enough fuel (even at 90%+ duty cycle) to keep up with whatever the the turbo is flowing (air). Your stock turbo cannot outflow the stock injectors.
If you want more power then you will need more air and more fuel. The "more air" part comes from a bigger turbo, and the more fuel part comes from higher flowing injectors and a standalone EMS.
thats the simple answer.....
