Those are the pintle caps and they regulate the spray pattern. Available online. Old ones become brittle and break easily.willmoodom wrote:Anyway, at the bottom of the injectors is this plastic piece with 4 arms, appearing to be caps and holding the pointless on. After removing one it turns out that there not holding anything on. What are they for? And are there no replacements if they are needed? Although they may be broke, is the injector still good? Ill try to post a pic of what I mean or am talking about.
you have a web site?maxnix wrote:Those are the pintle caps and they regulate the spray pattern. Available online. Old ones become brittle and break easily.willmoodom wrote:Anyway, at the bottom of the injectors is this plastic piece with 4 arms, appearing to be caps and holding the pointless on. After removing one it turns out that there not holding anything on. What are they for? And are there no replacements if they are needed? Although they may be broke, is the injector still good? Ill try to post a pic of what I mean or am talking about.
http://www.mrinjectorparts.comwillmoodom wrote:you have a web site?maxnix wrote: Those are the pintle caps and they regulate the spray pattern. Available online. Old ones become brittle and break easily.
thanks. you got pm.Q451990 wrote:That metal part you mentioned is just an insulator or spacer that keeps the injector aligned in the rail cap. They are available separately from the dealer.
Heath
I wasn't aware of the amount, but Bill is a real straight shooter. Let us know how it turns out.willmoodom wrote:Thanks a bunch maxnix!! whether you know it or not, you saved me 600 bucks or more.
No. 90-93 are different than 94--96.VipQ45 wrote:U know if the 90-93 injectors r the same?
Early are single pintle and really do not like ethanol.VipQ45 wrote:U know if the 90-93 injectors r the same?
