oi138 wrote:No you have enough fuel w/ stock injectors to warrent roughly 200 rwhp.
As long as he is using a RFPR. Stock injectors with stock fuel press won't cut 200rwhp.
Now if your going with bigger injectors I wouldn't recommend using a RFPR. If you can tune it down to 315cc it might work. I beleive Adam was runnning 310s in his KA24ET without any fuel management. It was rich at idle but he says it worked.
You can always try it out and if it doesn't work change AFCs.
Intake makes no real difference in a turbo setup (except for making the compressor's work easier), and headers are not used in a turbo setup.
