Thanks, but don't what add any other brandbeans33 wrote:Take a look at injector dynamics. I've heard great thing about them.
I figured that, just think maybe some be most compatible than other o some s*** like thatboost_boy wrote:Either will work just fine.
Damnfloat_6969 wrote:I'm running 50psi of base fuel pressure.
float_6969 wrote:I'm not sure what you're asking, but I think there is an easy way to change injector size in nistune.
Yes there's a simple way to change that in the nistune but nothing describe about the fuel pressure,r34 gtr wrote:Well, it would depend on what fuel pressure the new (1000cc) injectors were rated at, but yes the pulse width would most certainly need to be less to net you the same amount of fuel as with the stock injectors.
You need to use the wideband air fuel ratio meter to tune the K Value and injector dead time.Luchitosan wrote:
at least in the notes i' ve but, I guess from 40 psi might work
Agree !beans33 wrote:Take a look at injector dynamics. I've heard great thing about them.
Ok, first need find out info and yes have a FPR.float_6969 wrote:If you have an adjustable fuel pressure regulator, you need to set the base fuel pressure to whatever the fuel pressure the injectors were rated at. If you don't have one, then you need to contact the injector manufacturer and find out what the fuel flow is at the pressure your regulator is set at. Then use that flow amount to change the injector size in Nistune.
louiswun wrote:You need to use the wideband air fuel ratio meter to tune the K Value and injector dead time.Luchitosan wrote:
The result of the "simple way" is accurate ONLY IF the injector dead time is the same as stock injectors.
but usually hi flow injectors had higher dead time, so, the K Value must have to tune for best result.
