Injector writeup?
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
So I looked under all the diy/mod the ca section and it looks like no one had done an injector install write up? If not anyone care to? (if someone did maybe Dee/TMS?) Searched for it but didn't find to much that is helpful other then really bland description that basically points out not to smoke while doing it lol Anyone down?Thanks
wynnEZ
Car: 90 240 CA POWA!
Its in the FSM. Read it.
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Ahhh totally forgot about that lol. But I'm sure someone on here might have a few tricks for making it a little easier:)?
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Ive already posted it somewhere. Basically, pull the fuel pump fuse and let run until she dies, then pull the rubber fuel lines. Undo your wiring harness that goes up there, remove the breathers and the little manifold braces, then the two 10mm bolts holding down the fuel rail. Then remove the whole thing, replace, and reinstall.
Not quite that simple, but that's the gist of it. Really really easy and should only take you 30 minutes at the most.
Good luck!
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Sweet, thanks R34 that's pretty much what I was looking for. And 30 min. sounds alot better then 2 hours lol
wynnEZ
Yeah it took me about 45 mins doing it the way in the FSM, although Ive heard it took someone 3 hours... All based on you.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
r34 gtr wrote:Ive already posted it somewhere. Basically, pull the fuel pump fuse and let run until she dies, then pull the rubber fuel lines. Undo your wiring harness that goes up there, remove the breathers and the little manifold braces, then the two 10mm bolts holding down the fuel rail. Then remove the whole thing, replace, and reinstall.
Good luck!
took me nearly 2 hours to do........... all because I didnt realize the 14MM bolt at the rear of the manifold was holding the fuel rail down.
ganma_ca
Car: 240sxxx
1CA +1SR = 3.8L
Yeah when I first took a look at a glance thought I'd have to take the whole intake mani off, t.g. that's not the case!
