The harnesses for the CA18DE and CA18DET RWD platforms are slighty different in the fact that the DET requires an injector resistor and also has a solenoid for boost control.Rambo24o wrote:Hi I was wounding of the CA18DE and the DET have the same harness Or if I could used any other injectors wireing for the CA
What are you trying to do? What are you currently working with (ie CA18DET with no harness or CA18DE with no harness)? Let us know know as someone on here maybe able to assist you.Rambo24o wrote:Thaxs a lot I will try to find resistor box and a CA18de harness
