CC/min = lb/h x 10.5
lb/h per injector = (expected bhp x .55) / number of injectors
Calculating for a 4 cylinder engine (rounding up to next integer):
250BHP - 35 lb/h or 370cc injectors (maxed out)300BHP - 42 lb/h " 440cc " " 350BHP - 49 lb/h " 515cc " "400BHP - 55 lb/h " 578cc " "450BHP - 62 lb/h " 650cc " "500BHP - 69 lb/h " 725cc " "550BHP - 76 lb/h " 799cc " "600BHP - 83 lb/h " 872cc " "
Approx. fuel increase due to 50HP increase is 7 lb/h or 75cc.
WHP = BHP x .8 due to estimated 20% drive train loss -> 300HP = 240WHP
Quote from Corky:"The .55 figure is actually the maximum load brake specific fuel consumption (bsfc) of a typical turbo charged engine. In general the number of injectors is the same as the amount of cylinders. Clearly one should choose the next larger size than the calculated value, to offer some margin for improvements."
I'll add to that; improvements AND safety.
I know that those injectors sizes are not quite the same as those used by most injector manufacturers, but I assume you will know to round up a bit when you are selecting your own injectors. For example when you know that you aim for 240WHP, which is 300BHP, and you choose the 515cc injectors (remember one size up), there will be very few if any manufacturers of that specific injector size, so you should go with the more common 550cc injector, which will offer even more of a safety/improvement margin than the one calculated/chosen.
This is also a method/chart erring somewhat on the safe side, but I think that most of us will agree that it's the best way to go
sil80
P.S.: These formulas can be used for a 6 or 8 or however many cylinder engine you'd like, by substituting those numbers instead of 4, on the division part of the second formula.
