Ca_Silvia »
https://forums.nicoclub.com/ca-silvia-u34581.html
Sat Apr 26, 2008 11:22 am
My car ran fine no gas leaks or anything. I then boost leak tested the system fixed all my leaks and then went to start the car and my #4 injector is pissing out gas from the o-ring that seals it to the fuel rail. I can gently pry on the injector moving it up and down but it still will not seal.
How the hell did compressed air do this?
Any tips/tricks to making it seal without removing the whole fuel rail again?
Can i remove the fuel rail without taking off the upper manifold?
Note: i am to scared to pry with force on the injector up in to the fuel rail. Is it worth a shot? Not reccomended? What could i break?
I know its alot of questions but I hope i can just pop it into place. Thanks in advance guys.
