Qdog wrote:Got to the knock sensors, they test at 562 & 569K, but each has a small crack. Should I re-install them, seal the crack (permatex ?)or replace ? Original, I think, with 160K miles. Not that I would, but couldn't one replace a bad knock sensor with a 550K resistor and live dangerously, but fool the ECU ?
Replace it if it's cracked. Even if it ohm's okay, it won't work right and will likely be intermitant - sometimes it will be open and then ECU will go failsafe for the next 50 starts.
Change them unless and only unless the cost will be a severe hardship. Basically then you'll be trading drivability, performance and possibly gas mileage for the $300 you didn't spend on the sensors. I predict that if you don't change them, in about 6 weeks you'll have a gnawing sense that you'll wish you had.
