I wonder what the recall was for? Same Phase one injector design but Infiniti's were never recalled.Q451990 wrote:It might be worth checking to see if the M30 was part of the injector recall... I seem to remember something about some M's being part of the same recall as the 2nd generation Maxima recall in the mid 90s.
Other than that, I don't have much to offer...
Good luck!
Heath
is this spacer different from the ones connecting the injectors to the rail?the new injectors came with rubber seal on the bottom. and a new seal kit came with 1 small and 2 larger rubber seals.Q45denver wrote:
Also you might need to replace the hard rubber seal/spacer on bottom of fuel rail.
