Injector question.
g-man
Car: 1991 240SX
I have a top mount fuel rail that I want to use om my s13 sr20det engine. It says I can use either msd, rc, or nippon denso injectors. The question I have is how do I know which ones are compatible with the connectors on my engine. I am planning on running 550cc injectors. Any info on this plus where I can buy them for a good price would be appreciated.
Nismo_Freak
Car: 89 Nissan 240SX
g-man wrote:I have a top mount fuel rail that I want to use om my s13 sr20det engine. It says I can use either msd, rc, or nippon denso injectors. The question I have is how do I know which ones are compatible with the connectors on my engine. I am planning on running 550cc injectors. Any info on this plus where I can buy them for a good price would be appreciated.
You need to buy connectors for the injectors.
Typically you can order them from the same place.
Then you just solder the new ones in, or if you have the proper tools you can just push the pins out of the old clips and replace them, then plug the pins into the new connectors.
I have a small kit from Snap-On that has all the pin tools. Works well and is good quality.
