injector question
mirra32
i can get a set of injector off of a 88 N/A rx7( i'll have to get 2 more of those 460cc right) . so these are top fed right. what do i need to get to make them fit my 95 de motor. i read that they fit but do i need anything special....i found several posts...but not to sure still.....
can i use the fuel rail off of a e motor..
i found a spread sheet with
Mazda FC NA Top feed 460cc yr 88 purple part # 195500-1350
also what about the fuel pump off the rx7 could i use that as well.....
thanx....
i'm piecing stuff to go turbo so work with me...im just getting things straight...
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
its not really worth it to use top feed N/A FC rx7 injectors because they are top feed which means you will need a custom fuel rail and fittings and probably harness connectors, then since they are used you should really get them flow checked... which costs even more money .... its definatly cheaper to get sr 370's instead for a DIY turbo kit unless your gonna make over 250whp off the bat...
mirra32
thats what i needed to know....thanx...just want to pick the right stuff up at the right price know what i mean.....
eric
