injector Q?
Frankenstien93
Car: Nissan 240sx SE
this may sound like a stupid Q but if i have a set of 550cc injectors for and SR will they fit in my KADE? they look the same but do the two engines use the same fuel systems?
j-z
Car: 95 240sx
yeah theyre interchangable. theyll work.
Frankenstien93
now should i upgrade my fuel rail too or would it be ok if i still used the stock one? im haveing trouble finding a side feed rail all i can find is a top feel are they better?
WDRacing
The stock rail will work fine. 550's have been used with the stock rail plenty of times with no issues.
WD
Frankenstien93
ok thats good to know. does anyone know aprox what hp do those injector max at? thx in advanced
virus77
Car: 95 S14, 71 240z, 97 e320
you can get a safe 350whp from them.
lrb_2000
Car: '91 Nissan KA-T hatch
here's something useful.
WDRacing
If you have 1 or 2 good fuel pumps and a good regulator you can increase the base pressure therby increasing the effective duty cycle. I cranked mine to 55 with vacuum and was able to boost my car to 19-20 psi with 42lb injectors. My AFR over 4800 started to lean out to almost 13:1 though. So you need to really be careful, I have a wideband and a knockmetter so...
This will be different on every car, I'm just giving an example.
Florida240sx
I got my tomei 555cc injectors from Mark who had an SR20det.... Direct drop in...make sure you don't tear the orings
