Injector Q's?
Oatmealman
Car: 2011 ford f150 fx4 5.0 master race
Hey
I need 2 injectors (4&2) but, I need to know if all the injectors are the same thing? Do 1/4 have a set and 2/3 have a seperate set? I have seen websites that only sell one kind, and others that sell based on Cylnder #...
Can someone please help?
Nismo1182
Car: Z06
when i took mine out to replace the o-rings, they all seemed to look the same to me. Same part #.
Aries
Car: LT1 240SS
they are all the same. :)
Oatmealman
thanks
240fan
can I clean the injectors, or do they have to be replaced (150,500 miles!) its idling like dung. 93 ka24dewho has cheap injectors that work, autozone? ABC Nissan wants $90 each! thanks for any info
Aries
Car: LT1 240SS
Ford actually sells the best injector cleaner.They'll ask you if you have the machine for it, just tell them yes and nothing more ;)
Pour the cl4eaner in a bowl and let the Injectors sit over night.Next day re-install them.
240fan
Thanks, I got the stuff but broke 3 of the injectors at the red plastic part, there is a ring on top with a metal washer ,a rubber seal and a plunger in the center. It looks like a seal in case the center plunger leaks, is this a non critical area? I am concerned since its going to be 30 or more each if I cant use them at http://autopartsgiant.com/
240fan
95_240sx
Car: My baby (car)
I got 4 injectors off my donor KA still in the fuel rail. You can take them for cheap cheap cheap.
Email me at [email protected]
Rick
TomsMR2
Car: cars.. etc
unsaid law of pick n pull junk yards.. if it fits in your pocket.. its free :D
i got some 270cc injectors for my MR2 :D
95_240sx
Car: My baby (car)
mr2's are top feed right?
Rick
team23rulz
3 of my injectors are clogged....i let them sit in gas overnight, will that do any harm to the electronics of the injector (they are not completely in gass, just the bottom is)
Also, where possibly could i get bigger aftermarket injectors?
95_240sx
Car: My baby (car)
there no electronics in a fuel injector, there is only a electromagnetic solenoid that open when it gets a charge through it.
Rick
240fan
got 4 nice rebuilds from Autopartsgiant and it ran great for 10 minutes, I drove it, then an hour later it cranks and cranks and finally started, and idles rough. do you think its one of the lower O rings isnt sealing on the new injectors? there was a puff of grey smoke when it finally started. it almost stalls in idle too :-(
