cheapscheisst »
https://forums.nicoclub.com/cheapscheisst-u51432.html
Thu Nov 22, 2007 10:28 am
alright. so i just got my dohc motor into my '90 chassis, got everything hooked up and wired up, egr blocked off, and i crank it over. it cranks over great, but doesn't fire up. every so often, i hear a slight pop. i checked all four plugs and wires, they spark fine. so i get to the fuel rail and take it off. then i see that the injector ground that comes out the the injector wiring casing was sandwiched in between the rail and the casing (it was hidden so i missed it when i went over the harness). so i grounded that wire and had a friend crank the car, no fuel spray at all. however i do have fuel pressure. does anybody have an idea of what could be wrong (not causing the injectors to open)?
